Review of Meridian G68 & G98
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by recruit, Mar 29, 2005.
  1. recruit
    recruit
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,739
    London
    +1,075
    An interesting review - thx for the link!
    How are you getting on with your setup btw?
  3. rags
    rags
    Apr 13, 2003
    4,089
    London
    +323
    Thats a cracking review to be honest. He seemed to love everything about them !
  4. recruit
    recruit
    I can't stop listening to it :D
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,739
    London
    +1,075
    If only I had the money! ;)
  6. dmurfet
    dmurfet
    Thanks for posting that recruit. :thumbsup:
    I assume your decision was an easy one to go all Meridian?
    Did you try other front ends at all on your travels? I am tossing up between an all Krell system or the two Meridians in the review (but the balanced processor) with Krell power.
  7. GaryG
    GaryG
    Nov 20, 2002
    744
    Shropshire
    David
    Can't comment on the Krell processor but I find the G98 works well with Krell amps via a 568.2. Last time I auditioned a G68 it wasn't possible to disable the MHR on the digital outputs which ruled it out for me as I use the L/R digital outputs to link my HiFi and AV systems together but it was a cracking AV processor although a bit too clinical on music for me. If music is a priority and you don't want to muck about with a seperate DAC check out a used 861, it's pretty impressive, mine's a pretty old v2 with v2.5 software but it's very musical in comparison to a G68.
  8. dmurfet
    dmurfet
    That could be a very good idea actually it gives me a cheaper crossover to proper pre / power and a subsequent upgrade less painful. Does the 568.2 have balanced outputs? What is the going rate for them? and do I need to ensure current upgrades for them?
    David
  9. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    845
    +99
    The 568.2 has balanced outputs for the front 3 channels.
    Latest (V2.5 beta) firmware gave the unit PLIIx and THX Ultra 2, along with a slightly different soundstage (more detailed). Some people prefer the older firmware, but I personally liked the later V2.5 sound.
    Current pricing is around £1500 to £2200 depending on the spec and how lucky you are on the day. :)
  10. recruit
    recruit
    Hi David,
    Yes it was an easy decision for me anyway, as i had always wanted to own one and wanted a good balance for Movies and Music.
    I have heard a couple of others ie Lexicon / Parasound but never a Krell setup but from what reviews have been written i am sure it will be good.
    Ref to the 568.2 it certainly does represent good value for money especially at the current priceing that scott has quoted, before i bought the G68 i was offered an Ex dem 568.2 at a good price and definitly thought about it but after talking it over with my dealer i decided not too as the Benefits of the G68 over the 568.2 were more appealing to me ie Room Correction which IMO is definitly something that effect's most peoples listening rooms.
    Apart from it also sounding superb it's looks also appeal more to me than the older 5xx series which IMO are quite ugly looking, i suppose if it is in a dedicated room then that won't really matter but mine is on show so it certainly helps.
    John
  11. GaryG
    GaryG
    Nov 20, 2002
    744
    Shropshire
    David
    If it's of interest I may be parting with my G98 (Audiocom mod'ed) and one of my processors, either the 568.2 or the 861, over the next month or so. I'm having a real problem with Tinnitus lately and am not able to listen to my system these days, will probably get shot of my Wadia transport/dac and Krell monoblocs as well.
  12. recruit
    recruit
    Hi Gary,
    Can i ask you a question, what do you mean by audiocom moded?
    John
  13. GaryG
    GaryG
    Nov 20, 2002
    744
    Shropshire
    Hi John
    Here's a link to the Audiocom site:
    http://www.audiocominternational.com/
    They offer a number of modifications for upgrading Hi-Fi kit. Although the G98 is a great transport I felt there was room for improvement and gave Audiocom a budget of £1000 to see what they could do with it. Their comment was that the strength of the G98 was in the design, but it's built to a price, they changed a number of key components to extract a little more out of it. The modified version is less harsh and grainy in the treble, a nice smooth presentation now. Having said that, they can only work with what's there, even a modified G98 is no match for a Wadia 270 for RBCD.
  14. recruit
    recruit
    Cheers for that Gary :thumbsup: that must be an absolutely awsome G98 as it is very good as it stands and to be improved upon WOW very interesting indeed. I will have a look into this.
    David - If you are thinking of getting one then if Gary is selling his that would be an excellent choice especially as it has been enhanced even further!!
    John
  15. dmurfet
    dmurfet
    since I just got the dv27, then another dvd is at the bottom of my list atm. I am about to order a dedicated cabinet from kell systems, then my next move is a processor. But I want to end up with matvhing set since both krell (cast) and meridian (can't remeber the technology) both get better when you pair them up. So if I get a 568.2 or a g68 (i want the balanced one) I will end up with their dvd - the same for the krells.
    Looks like I can get 568.2 for just short of 2k which might be a good stepping stone. I think I'll be in the market for one in 6-8 weeks time depending when my customers pay me! I guess I really need to hear both, with my system and my room, but that is easier said than done!
  16. dmurfet
    dmurfet
    of course if there is a deal to be done then I'm not going to look a gift horse in the mouth!
  17. dmurfet
    dmurfet
    Thanks for this Scott
    :thumbsup:
  18. u32t5645
    u32t5645
    I have seen this expression appear in several places on the AVForums. For those of us on this side of the pond, what does “cracking” mean?
    :confused:
  19. GaryG
    GaryG
    Nov 20, 2002
    744
    Shropshire
    Vernacular for 'excellent'.
  20. u32t5645
    u32t5645
    Thanks!
  21. mattmarsden
    mattmarsden
    Mar 6, 2002
    1,543
    48
    +97
    I am really tempted to get a G68 now, but I am bothered by the imminent arrival of HD-DVD/Blu Ray and want my processor to be able to decode the new formats.
    Is the G68 upgradeable or will a new version come out?
  22. recruit
    recruit
    The G68 is upgradeable by software only at present and i don't know if Meridian will make it hardware too?? saying that though my G68J has 3 panels blanked out that could possibly take future hardware upgrades.
  23. mattmarsden
    mattmarsden
    Mar 6, 2002
    1,543
    48
    +97
    As much as I'd like to buy one now, I think it would be a bit silly until HD-DVD is out and we know the score with what formats a prcoessor is going to need.
    I would also like it to have HDMI/DVI switching and iLink for SACD.
  24. recruit
    recruit
