review my setup please
Discussion in 'Networking & NAS' started by jensondegroover, Jan 11, 2012.
  1. jensondegroover
    jensondegroover
    Aug 1, 2008
    39
    hi all,
    im with Sky and have been for many years. Im currently using the supplied Netgear unit which at a guess must be 6-7yrs old
    over the years my stuff has updated and I feel I need an update on this also
    Im unsure if Im allowed (as in sky T & C's) to use something else? as ive heard poor reports on the Sky supplied N router at £35 :confused:
    counting up Im running the following by Cat5 cable:
    two new xbox
    1 sky HD box
    1 tower pc
    via wireless
    one laptop
    one Ipad
    two HTC Desire HD
    the cabled stuff runs without a hitch, and to be fair so does the laptop via wireless, however the Ipad is slow unless its used in the same room as the Netgear. The HTC's refuse to connect anywhere in the house other than that room also:thumbsdow
    Im hoping it may be as simple as swapping or adding something like an N router to my system to get everything running reliably like the cable stuff does.
    please im a little bit lacking in the tech speak dept so keep any suggestions basic :laugh:
    many thanks :smashin:
  2. themediaman
    themediaman
    Nov 17, 2010
    2,017
    Glasgow
    +171
    from your description it would seem the range of the router within your property is lacking, so it may be struggling to get through walls etc....
    I believe you could get a hold of another router, with better range etc, wireless n as you say and it should operate fine.........
    Not with sky though, so hopefully someone can confirm this..........
    will sky not provide you with a better router free.......?
  3. LKEK1985
    LKEK1985
    Nov 26, 2008
    1,355
    Essex
    +54
    Yes you can buy your own router and configure not a problem. buying a decent £50-£60 router you will notice a speed increase on the LAN.
    Make sure the router your purchasing is Wifi protocol N, this in the latest technology and offers best speed and wireless range.
  4. LKEK1985
    LKEK1985
    Nov 26, 2008
    1,355
    Essex
    +54
  5. jensondegroover
    jensondegroover
    Aug 1, 2008
    39
    thanks for the suggestions and advice guys
