reveiw for acoustic energy ae1 signatures
Discussion in 'Home Cinema Speakers' started by andrew constant, Apr 12, 2003.
  1. andrew constant
    andrew constant
    Apr 15, 2002
    209
    london
    +10
    does any one have a reveiw of these speakers as i have just brought a pair .
  2. eddiea
    eddiea
    andrew
    Are yours the MkII or MkIII?
    I used to have a pair of MkIIs, I have seen several reviews on these, just do a search on google.com .
  3. andrew constant
    andrew constant
    Apr 15, 2002
    209
    london
    +10
    I brought the speakers 2nd hand and was told they are 4 years old .
  4. eddiea
    eddiea
    Probably MkIIs then, it should say on the label on the back where the serial numbers are, they are fine speakers, loved mine but discovered HT and bought a Monitor Audio Gold Centre then decided to change the AE1s for MA Gold 10s to match the centre.
    Did you find any reviews?
  5. eddiea
    eddiea
    PS what did you pay for them, I think they were about £2K new!
  6. andrew constant
    andrew constant
    Apr 15, 2002
    209
    london
    +10
    I boght them for £820. I saw them on ebay and in loot to they come with the original stands what weigh a ton.
  7. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    I have the stands and they are a worth a bit on their own. Filled with sound bites, they are virtually un liftable but the best stands I have /heard. Bought AE1 and AE2 stands, now just saving up for the speakers :blush:
  8. eddiea
    eddiea
    You got a bargain, I biwired mine with VDH T Track.
    :cool: I still have my AE1 filled stands, my MA GR10 sit on them, like you say they weigh a ton.
  9. andrew constant
    andrew constant
    Apr 15, 2002
    209
    london
    +10
    my kit at the moment is arcam alpha 10 + p amp
    and marantz cd 17 sig, cable vdh cs122 also connected to a pioneer vsa-e08 av amp ,,and a arcam dv 88 dvd with some mission rear speakers , and a tosh 36 zd26p tv
