Return Policy by Manufacture for Pixel Failure
Discussion in 'LCD & LED LCD TVs Forum' started by Glenagoolie, Aug 4, 2005.
Tags:
  1. Glenagoolie
    Glenagoolie
    Jul 21, 2005
    164
    +5
    Hi all,
    regards LCD's does anyone know do manufactures have a set pixel failure - replacement rate or does it vary from model to model. I'm interested in getting a 32" LCD but obviously don't want any pixel failure and webshops generally say that it's down to the manufactures guarantee. It's not a generally listed item on their specs
    thanks
    Ronan
  2. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    It's always been manufacturer policy as far as I know, I don't think they make exceptions for different models. Maybe different screen sizes, though.
  3. Rob1698
    Rob1698
    It probably depends on local law. Here in the Netherlands, the shop is always fully responsible for any quality problem. The shop decides whether they want to solve problems themselves or have the manufacturer solve things, but the customer is not involved in that.
    However, that usually means that a definition of quality is part of the deal. So when your agreement is that you will have zero defects, you can get the unit repaired, but when you have made no special arrangements there will probably be fine print on the back of your invoice that says that some pixel defects are normal and are to be accepted.
