Quantcast
Question Retiring my AE900... So temper my expectations
hander
AE900 retiring - bought using the profits from a bet that Sol Campbell would score in the 2006 CL Final vs Barcelona.
I'm looking for a replacement, which will be mainly use in my small office for video, maybe some gaming and casual presentations.
I use three monitors on main PC in the office and I would most like to mirror one of these screens to the projector. The monitors have VGA, DP, DVI inputs and vary in resolution - 1600x1200, 1920x1200, 2560x1440. (Ideally, I'd like to be able to select between them easily).
Min requirement for screensize at throw of 2.6m = 65-70".
Needs to be bright enough to work during daylight, but can darken the room when necessary. The room has light grey walls but I'd consider installing a screen.
Budget is up to 1K - ideally including screen if that becomes necessity.
Are my expectations realistic?
