Resurfacing DVDs
Discussion in 'Movie Forum' started by Jonesthegas, Jul 6, 2003.
  1. Jonesthegas
    Jonesthegas
    Jun 5, 2002
    628
    Newcastle upon Tyne
    +18
    A friend from Australia, who has a daughter and hence severely scratched DVDs, has had some of his collection resurfaced.
    I have the same problem. Anyone know if it can be done here and by whom?
    Martin
  2. Mike Swannick
    Mike Swannick
    Sorry to be so vague, but I do recall seeing a website recently which advertised prices for repairing scratched CDs/DVDs/PSgames/etc either singly or as a batch. It was a UK based company so should be out there somewhere.
    All they did was remove a fraction of a millimetre of the plastic which covers the recorded material. This is something you can do yourself with any abrasive cleaner like T-Cut, although not to the precise measurements like the pro's.
    Try Disk Doctor too which uses a fine grade (about 1200 or higher) wet n dry type abrasive paper on a rotating wheel, although the build quality of these units is a bit suspect for the price (~£30.00).
    I'll keep looking for the disk repairers.
    Edit: - http://www.fucd.co.uk/fucdallproviders11.06.03.htm
  3. ebury
    ebury
    Nov 5, 2002
    1,250
    41
    london
    +12
    Thatzdvd .com also do a scratch repair service.Meant to be top notch,but i dont no the cost.Sometimes you would be better off just buying again in a sale!
  4. j_morgan54
    j_morgan54
  5. jmcr100
    jmcr100
    Aug 14, 2002
    The Netherlands
    +15
    It costs about 3 quid to repair the discs by thatzdvd. I cannot vouch for quailty etc. because I've never used them for repairs but it sounds reasonable!!!!
  6. Jonesthegas
    Jonesthegas
    Jun 5, 2002
    628
    Newcastle upon Tyne
    +18
    Thanks guys.
    Martin
  7. CENSORED
    CENSORED
    What's wrong with SkipDr.? Cheaper and (mostly) amounts to pretty much the same thing.
  8. dnrc
    dnrc
    Dec 23, 2002
    300
    16
    Near Norwich
    Do it yourself with t-cut.
    Trust me, this works a treat.
  9. encaser
    encaser
    Mar 15, 2001
    1,566
    Suffolk/Essex
    +112
    I've used thatzdvd and can vouch that they are excellant to deal with. They managed to recover a now deleted cd which got well and truely squiffed in an errant cdrw.
  10. phenom2003
    phenom2003
    Brasso metal polish works a treat, out of the 10 s/h ps1 games I bought that didn't work, repaired 9 of them.
