Results of JS RGB/VGA 'upgrade'
Discussion in 'Plasma TVs Forum' started by nobbydog, Jan 22, 2004.
  1. nobbydog
    nobbydog
    Jun 19, 2003
    262
    Comfy basket in the utility room
    Just thought I'd share this with the forum members.
    Took delivery of the above converter yesterday. I was originally running a Thor scart from my Panasonic Sky box direct to a scart input board on the P6. Seemed OK at the time. The difference running into the VGA through the JS box is very noticeable. Although I cannot detect any significant improvement in picture detail, the colours have definitely gone up a notch or two. Colours are definitely more vibrant and, as there is no colour level control in the VGA input menu, my only problem now is to fiddle with the advanced settings to try and reduce the depth of colour. The acid test was to watch it for several hours and, as quickly as I could, reconnect via the scart board. This really showed the difference up as colours looked very washed out and lifeless in comparison.
    Money well spent, I'd say, but not cheap. Total cost around £145 with VGA lead.
  2. TP2K
    TP2K
    Nov 14, 2002
    523
    16
    Interesting - I really want one of these, but £145 is a bbig risk if it's incompatible with my Hitachi PD3000... anyone tried yet?
    The JS site states; "...Recommend RGB to Component Converter.
    Note, second VGA input may be configured for Component input on some models."
    - anyone any more clued up on this? TIA!
  3. bossc@
    bossc@
    Dec 20, 2001
    1,160
    +268
    Think its been covered in another post recently but I dont think the Hitachi will accept this coverter. The VGA on the Hitachi is configured with use only with the tuner box (and PC????) I think.
  4. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    The VGA connector on the 42PD3000 tuner definately works with a PC but AFAIK will not work with the JS converter.
    John
  5. a3rmk
    a3rmk
    Jan 17, 2004
    252
    Essex
    +5
    Bought my rgb > vga adaptor from Maplin @ £60/70.
    Used it for running XBOX through Pan plasma, now the picture is pin sharp and the colours better also.
  6. maxzorin99
    maxzorin99
    nobbydog
    I am also thinking of getting this, and i also have a P6. Does it go into the port that is reserved for a PC?
    and even though colors are better, is it a less 'soft' picture?
    Also, is any lip-sync problem made worse?
    cheers.
  7. bossc@
    bossc@
    Dec 20, 2001
    1,160
    +268
    Max
    I use the RGB/VGA converter with my PW5 and it does go into the PC input. Like all things plasma, the image is very much dependant on source. It is a softer image due to the nature and resolution of the panel for some channels ( I use NTL digital) but most are spot on. Even the wife is impressed, which says soemthing. I've had some issues with lip sync at times but on only the crap channels the wife sometimes watches (Discovery Health etc) but a simple change of channels and back helps that.
    Personal opinion I know but I much prefer this image to anything I could get out of the 42PD3000 when I had that.
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,769
    The Borders
    +3,088
    maxzorrin99
    With a Series 6 display you can use either one of two of Dr Johns converters - RGB2VGA or RGB2YUV.
    As the HD15 (PC) socket on your display takes RGBHV or YUV all you require is a suitable cable to suit whichever converter you choose.
    The RGB2VGA is very slightly better - though hard to spot unless you look really hard for the differences.
    Many of the customers we supply with the 6 Series and one of Dr Johns boxes favour the RGB2YUV as they may also have a DVD with YUV out and an AV Amp with YUV switching so can plug the DVD and Digibox via the Amp to simplify the number of connections to the display and system switching.
    Best regards
    Joe
  9. nobbydog
    nobbydog
    Jun 19, 2003
    262
    maxzorrin99
    Nothing new to add really, I have not noticed any better/worse lip sync, the only disadvantage to the converter is the lack of auto aspect switching. You get zoom, just, 16:9 & 4:3 which you need to select manually. Look in the powerbuys and I think you can get an auto switcher for £95 or so. I'm happy to manually switch for now.
    The only other slight problem is that the colours are so 'good' now that I've had to fiddle in the advanced settings to tone them down a bit - the colour option is not available through the vga input.
    Let us know how you get on if you decide to go for one.
  10. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    This is a "fault" of the Panny and not the converter, though nobby.
    It's the one drawback with using the VGA input; you loose the Just mode.
  11. mrsimes
    mrsimes
    Aug 21, 2003
    36
    You DO NOT lose the 'just' mode on the Panny 6 series.
    The Panny 6 supports 'just' via VGA. I am currently using it!
    S
  12. nobbydog
    nobbydog
    Jun 19, 2003
    262
    I think gmt steve meant that you lose the Panasonic Auto mode and that the 'fault' is the inability to have auto-aspect switching with the vga input and colour control in the menu.
  13. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    No actually I did mean the JUST mode, but I have a Panny PW5 which does loose JUST via VGA; I just assumed the PW6 was the same. Ooops, I'll just get my coat.
