Restoring Factory Settings?
Discussion in 'AV Receivers & Amplifiers' started by georgepenny, Nov 7, 2005.
  1. georgepenny
    georgepenny
    I've finally set-up my Denon 2106 with my Canton based surround sound set-up and I must as it sounds sweet, the auto-setup also seemed to work pretty good. Now the downside, i've been tinkering and playing with all the options and have messed up some settings put not 100% sure what I have done, is there a way of resotring the factory settings?
    George
  2. Jase
    Jase
    Mar 16, 2001
    10,960
    United Kingdom
    +3,435
    Yes. It will be in the manual under Initialization of the Processor. Hold down the Speaker A and B buttons on the front panel whilst turning the power ON. Hold them down for a couple of seconds and the display will flash and reset the unit back to the factory defaults.
  3. georgepenny
    georgepenny
    Top Man, thanks Jase
