Restart windows without powering off/on
Discussion in 'Microsoft Windows' started by IRobot, Feb 27, 2013.
  1. IRobot
    IRobot
    Jun 28, 2006
    1,883
    116
    Leamington Spa
    +1,049
    When I restart Windows, the PC will shut down Windows, completely power off the computer, power itself back on and then load Windows.
    It used to restart Windows without switching the computer off and on, so some setting has been changed somewhere.
    Anybody know what that setting is ?
  2. MiiCK90
    MiiCK90
    Nov 5, 2011
    855
    Newcastle
    +22
    Umm, clicking restart from the Start menu will shut down your computer and turn it back on...
  3. IRobot
    IRobot
    Jun 28, 2006
    1,883
    116
    Leamington Spa
    +1,049
    Before, it just used to go to BIOS and then restart Windows. Now it turns off fans, drives and everything before restarting. I just thought there was a reg edit or something you can do to change this behaviour. No big deal if not.
  4. nheather
    nheather
    Oct 6, 2004
    19,599
    167
    Horsham, West Sussex
    +9,808
    Applications usually advise a restart to apply some setting changes, but sometimes this is just playing it safe.
    Depends on what settings need reapplying, but often simply logging off and then logging on is sufficient.
    Problem is, other than trying, there is no way of knowing whether a log off/on is sufficent.
    Cheers,
    Nigel
  5. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,891
    2
    The Fylde Coast
    +13,532
  6. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,891
    2
    The Fylde Coast
    +13,532
    ^ Don't bother. Just tried it. :(
  7. IRobot
    IRobot
    Jun 28, 2006
    1,883
    116
    Leamington Spa
    +1,049
    "Shift + Restart" was mentioned somewhere. I tried it but, no change, still got a power off restart.
    However, I was going to check BIOS settings, so restarted Windows again, but this time the computer didn't power off. It loaded the BIOS then Windows. Tried it again and yep, it's fine now :smashin:.
  8. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,891
    2
    The Fylde Coast
    +13,532
    Shift+Restart was Windows 3.1/95/98 that I remember! Mine never switches off on a restart, it always just does a soft reboot on the bios. I thought you were looking for a restart straight into the "Starting Windows" boot logo routine!
