Ressurecting damaged cones
Discussion in 'Home Cinema Speakers' started by tuttonp, Jan 21, 2003.
  1. tuttonp
    tuttonp
    I'm in the process of possibly buying a set of Eltax Liberty speakers (Liberty 5.0), however the floorstanders mids have had the centre of the cones pushed in, as has one of the mid cones on the centre!!. Although sonically the APPEAR ok I'm not sure. Is there any way of simply getting the cones back out (vacumn??, pushing them out from behind??) or is it a case of once they're in they're in and walking away from the deal??
  2. dnrc
    dnrc
    Dec 23, 2002
    300
    16
    Near Norwich
    Personally, I would give it a miss m8. Probably more trouble than it's worth.
  3. juboy
    juboy
    That said, it is actually disturbingly cheap to have entire drivers replaced in all but the most high end speakers.
    You might only be looking at £15 to £25 to have brand new ones put in.
  4. tuttonp
    tuttonp
    juboy - Thanks for that. I'm waiting on Richer Sounds giving me an idea as to what each will cost to replace.
  5. ReTrO
    ReTrO
    Jul 12, 2000
    3,506
    2
    71
    High Wycombe, Bucks, UK
    +59
    There's probably nothing wrong with the drivers. A bit of suction with a vaccumm cleaner should do the job. They'll only really need replacing if the outer cone is damaged (not the central dust cap) or it is a tweeter.
