Response Times - LCD's
Discussion in 'LCD & LED LCD TVs Forum' started by Damo121, Sep 24, 2004.
Tags:
  1. Damo121
    Damo121
    Jul 4, 2004
    866
    +28
    Is it the higher the response time on a LCD, the better or the worse.
    Damo :)
  2. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Lower response times = better picture, i.e. less smearing as the individual pixels can switch brightness/colour faster.
    Higher response times = worse picture, picture can be prone to smearing as the pixels lag behind what should be displayed.
    S.
  3. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    Thats not totally true Steve you might get a lightning fast panel which has poor contrast and brightness.
    But the lower the Ms steve is right, the less ghsoting or blurring you will see on fast action scenes
  4. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Ironduke,
    Perhaps I should have been more clear, I didn't mean to imply a lower figure meant a panel could have better contrast/brightness... a lower response figure means that a pixel can change state faster. For a pixel to change state it is changing from one colour to another or from one brightness value to another. Of course as you say if a panel has lightning reaction times but an overall contrast ratio of 50:1 it'll still look utter pants.
    The original question was relating to response time only and no other factors.
    S.
  5. richard plumb
    richard plumb
    Jan 27, 2002
    14,495
    Windsor
    +1,051
    For what its worth, its quite straightforward. a 16ms response time is quick enough to support 60Hz updating, so would be enough for any NTSC video source, or games console in 60Hz mode.
    Many PC monitors are often 25ms, which is slightly slower, but not the end of the world if budget is the main issue.
    16ms is also the threshold at which a manufacturer can describe its sets as LCD 'TVs' and not monitors.
