Response/Refresh Times?
Discussion in 'LCD & LED LCD TVs Forum' started by Batch, Oct 1, 2005.
Tags:
  1. Batch
    Batch
    Sep 27, 2005
    2,702
    83
    University: Lancaster, Home: Cambridgeshire
    +200
    Is 25 or 16ms good for gaming?
    Batch
  2. MADMAND
    MADMAND
    Aug 4, 2005
    356
    +8
  3. Batch
    Batch
    Sep 27, 2005
    2,702
    83
    +200
  4. MADMAND
    MADMAND
    Aug 4, 2005
    356
    +8
    Yes it should be fine as panasonic use IPS lcd technology which have very good response times i.e 16ms IPS is as fast as 10ms TN-film
  5. mo
    mo
    Jul 16, 2000
    769
    london,england
    +23
    hi,
    as your on the subject.
    metz will be bringing out there own lcd tv in the next month or so .
    the top of the range stuff will have a response time of 7 m/s !
    oh, there making there own panels too !
  6. Batch
    Batch
    Sep 27, 2005
    2,702
    83
    +200
  7. MADMAND
    MADMAND
    Aug 4, 2005
    356
    +8
    You will see ghosting/smearing on that model. Toshiba/Panasonic/Hitachi use IPS lcds panels.
  8. Batch
    Batch
    Sep 27, 2005
    2,702
    83
    +200
    K, Thanks. Panasonic it is then!
  9. Batch
    Batch
    Sep 27, 2005
    2,702
    83
    +200
    7ms, WOW
  10. MADMAND
    MADMAND
    Aug 4, 2005
    356
    +8
    If possible demo the model your after along with others. What will the primary use be gaming?
    I take it you have the read the article in post #2
  11. lazarus
    lazarus
    Oct 30, 2003
    572
    +18
    the recent crown lcd that woolies were flogging has an 8ms response time.
    ive got one - absolutely no smear whatsoever.
    surely 7ms is no big deal ? :confused:
  12. andrewfee
    andrewfee
    Apr 27, 2004
    3,066
    +500
    A "true" 16ms (eg 16ms for every transition) display is capable of displaying a full 60fps. (62.5fps to be exact) Lower than that = higher framerates, but if you're a console gamer, you won't be going higher than 60 anyway.
    However, most manufacturers often quote "peak" response times, rather than the slowest, so even if a display is 12ms, 8ms etc, it may still have some transitions that are above 16ms. (generally in dark areas of a similar tone/colour)
    If you've got a 12ms or lower display though, it should certainly be able to handle games. (note: any fixed pixel display such as LCDs will "smear" slightly with interlaced sources - this disappears entirely with progressive scan)
    Often these ultra-low response displays (7ms or less) actually fare worse than most displays rated as 12ms, 8ms etc, as they're only focusing on getting the peak down low, rather than all transitions.
  13. Batch
    Batch
    Sep 27, 2005
    2,702
    83
    +200
  14. MADMAND
    MADMAND
    Aug 4, 2005
    356
    +8
  15. Batch
    Batch
    Sep 27, 2005
    2,702
    83
    +200
    Thanks. What's the refresh time on that the newer 20" LCD ^ from Toshiba? Will it be alright for gaming?
    Batch
  16. Rob1698
    Rob1698
    The smearing and especially the ghosting that you see on an LCD panel is only slightly related to the response time.
    That response time figure is just an easy way to slam other panels. Every time the newest panel has a 1ms lower response time so all the others are crap.
    In reality, the ghosting does not appear on the panel but in your brain.
    A CRT screen shows each image only very briefly, which your brain interprets as part of a moving scene. The short image appears at the correct spot, and in-between images are not visible because the CRT is dark at those times. When this is not happening quicky enough you see flicker.
    On an LCD, the panel stores the image and shows it continuously until the next image is sent to it. There is no flicker.
    But the brain sees a continuous image fixed at one point, followed by a new image where the scene has moved to a different point.
    It is unable to process this as a moving scene, instead you see a double image (ghosting).
    To solve this, you need a strobing backlight, that flashes only briefly for each frame and shows the scene in the correct location, then turns black again.
    Philips had announced a new TV to appear by now, that included this feature. However, it has been postponed.
    Until then you can try to find the LCD with the lowest response time, but it will not really solve the problem because response time is not that the real problem is.
  17. Laser Boy
    Laser Boy
    Jul 7, 2005
    40
    I have read this elsewhere, in PC Pro magazine i think. The article related to some manufacturers research into why very fast LCD panels still appear to smear movement. It's all about the way our brains are wired up apparently. As you say the Philips scanning backlight may be the way forward here.
  18. Batch
    Batch
    Sep 27, 2005
    2,702
    83
    +200
  19. MADMAND
    MADMAND
    Aug 4, 2005
    356
    +8
  20. Batch
    Batch
    Sep 27, 2005
    2,702
    83
    +200
    Thanks very much MADMAND! You've been such a great help!
    Batch
  21. dsb
    dsb
    flickering lcds are progress? - flickering is one of the less pleasant things about crts
