Resolutions at 60hz on a 4k tv
fliegenaffe
Posted this on the led tv forum, sorry if it's classed as a double post etc. I've got a Hisense M6600 4k tv.
i can get 60hz with 3840x2160 and 60hz with 1920x1080 but only get 30 hz on any resolution that is between these two. i am using my tv with my pc connected to it. is there a way of achieving 60hz with 2560x1440 (or any resolution near this)? I have a utility called CRU, which allows you to make custom resolutions. I created a [email protected] resolution, but it looks awful, very blurred etc.
richardb70
raymondo77
Probably not much help to you, but I've had no problems hitting [email protected] on any of the 4K TVs I've had over the last 18 months or so (from LG and Sony), running Windows 10 and a GTX980ti/GTX1080ti.
fliegenaffe
Is it an ATI or GeForce card, and display port or HDMI ur using as you may need an adaptor
Thanks for replying. i managed to fix it by getting an HDMI 2.0 cable, then switching on HDMI 2.0 in the menu, then creating a custom resolution in Nvidia control panel.
Greg Hook
Moderator & Reviewer
There is no such thing as a HDMI 2.0 cable.
fliegenaffe
Well that's what amazon reckons it is. Either way, it's the only high speed cable i have tried that has given me 60hz on all resolutions. Maybe the cable i bought actually supports the increased speed?
http://www.hdmi.org/manufacturer/hdmi_2_0/
ThuGLy
Yeah as op and Greg says.
HDMI 2.0b does not define new cables or new connectors. Current High Speed cables (Category 2 cables) are capable of carrying the increased bandwidth
