Resolution
Discussion in 'Desktop & Laptop Computers Forum' started by [email protected], Apr 19, 2002.
  1. m@rk
    [email protected]
    Jan 3, 2002
    1,222
    83
    Lincolnshire
    +374
    I have just discovered that my new laptop has an S-video socket on the back of it (it was never mentioned in the manual) and upon plugging it into my TV, it works a lot better than I was expecting.
    But my question is:
    I have a Toshiba 36" widescreen TV and obviously that does not run at 800x600 resolution. So what resolution should I aiming for?
    Following on from that, once I know the resolution I need, how do I set up Windows 2000 to produce that (I am assuming a registry hack).
  2. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    I've a feeling that whetever your desktop resolution, the s-video output will be limited to a standard PAL resolution.
    You may get improvements by setting your laptop to the same res but I don't know for sure.
    I would use Powerstrip to do the custom timings. I'm not sure you'll be able to get any interlaced resolutions working though. It depends on the graphics card.
    HTH
    Alex
  3. m@rk
    [email protected]
    Jan 3, 2002
    1,222
    83
    Lincolnshire
    +374
    Having had a 'play' with it (I knew I had an s-video lead somewhere), if I set it to 600x400, it is okay but if I set it to 800x600, it goes off the edge of the screen but I can 'pan' the screen in all directions to see it all.
    Therefore the PAL output (it also has an NTCS option) in not a fixed resolution.
    So all I need now it to find out what the right resolution is and I should be okay
  4. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    I'm sure powerstrip will have a setting for pal - which would include the correct amount of overscan but you could try 768 x 576 @ 50hz which is PAL as I know it.
  5. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Try for 720x576 if you can.
    Failing that most graphics card support 848x480 which will work fine.
