Resolution settings locked
Discussion in 'Desktop & Laptop Computers Forum' started by keelby1, Mar 31, 2005.
  1. keelby1
    keelby1
    Dec 11, 2002
    1,180
    38
    Grimsby
    +12
    Ive just bought a Sanyo Z3 and am trying to alter the resolution settings on my pc. Its locked on 800x600.
    I'm using a GForce TI 4200 Graphics card but cant find anything in its advanced settings
    Thanks in advance
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
  3. keelby1
    keelby1
    Dec 11, 2002
    1,180
    38
    Grimsby
    +12
    On the monitor settings it says the monitor is working fine and is using the correct driver.
    Ive emailed sanyo to see what they have to say-I'm sure its something simple
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    How are you connecting them, DVI or VGA?
    Try Powerstrip.
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    I've found that if using a generic monitor driver, in fact, I don't think I've tried a monitor or driver which didn't claim to be working fine.
    You should certainly see which one is currently loaded as many of them are limited in resolution. :)
  6. keelby1
    keelby1
    Dec 11, 2002
    1,180
    38
    Grimsby
    +12
    I'm using DVI
    I will try powerstrip
    I've just set up pc using a standard monitor and altertered the resolution without any problems.However when I reconnect to the projector, the resolution locks back onto 800x600
  7. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I suspected you were using DVI. What happens is that the graphics driver asks the display what features it has and what its' highest resolution is, sometimes this conversation goes wrong.
    Powerstrip is often able to force the graphics card to set a resolution even though it doesn't think the display can support it.
  8. inzaman
    inzaman
    Dec 16, 2002
    7,888
    Derby
    +941
    What do you have the Z3 set to, i had this problem with my Z2.
    There are two DVI settings in the Z2 (i assume this might be the case with the Z3) one for HDCP compliant and one for PC. I am pretty sure that when i set mine to PC i kept getting 800x600, when i set this to HDCP voila 1280x720 via plug and play.
  9. CTID
    CTID
    Dec 28, 2003
    735
    Far, Far Away
    +16
    aahhhh! This could explain why I'm having problems with my DMS. Via VGA all is fine and dandy, but with DVI-HDMI to a tosh dlp RPTV it's choas! If I manage to persuade it to go to something decent, as soon as I start MCE it reverts back to 640x480. Even if I force 720p or 1070i it still reverts back.
    Anybody know a solution to this then? Do I have to use a specific monitor driver? (I think it is set as default plug and play ATM)
  10. keelby1
    keelby1
    Dec 11, 2002
    1,180
    38
    Grimsby
    +12
    Ive installed powerstrip but it would appear by graphics card isnt capable of a 1280x720 resolution. However powerstrip has 'unlocked' the resolution settings. i assume it locked onto 800x600because that was the closest.
    Time to move onto the classified section i think.....
  11. zAndy1
    zAndy1
    Nov 26, 2002
    19,922
    2
    5
    163
    +7,033
    He bought the Z3 off me and I was using it with my HTPC at 1280x720 and it was perfect. That was using a Radeon 9600 card which I suggest might make a good investment as it just seems to work at 1280x720.
    Cheers,
    Andy.
  12. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I suppose it's possible the 4200 doesn't have the necessary custom resolution support it needs.
