Resolution helkp required
Discussion in 'Desktop & Laptop Computers Forum' started by UrbanT, Jan 1, 2005.
  1. UrbanT
    UrbanT
    Jan 6, 2002
    12,876
    Aldershot, Hants
    +3,036
    Hopefully there is a simple answer to this question.
    When I connect my HCPC to a projector using HDMI, there are only a few resolutions available in the ATI control panel, the highest of which is 1280 x 720 (native panel size)
    When I connect using VGA, the same resolutions are available, as well as the usual standard 4:3 options (1024 x 768 etc etc).
    The problem comes when I play Pro Evo 4. On the HDMI connection, the game offers only a few resolutions, including 1280 x 720, which is perfect
    Using the VGA connection, I get alot more resolution options in the game, but all 4:3, even though the desktop runs fine at 1280 x 720. These are all standard res's, I don't use Powerstrip.
    Any idea's how I can force Pro Evo back into 1280 x 720 using VGA?
    Cheers, Chris
    Basic Spec:
    Ati 9800 pro
    Cat 4.12 (happens on all the Cats I tried)
    AMD 64 3200
    Windows XP with SP2
