Resolution - Games - HTPC & PJ.
Discussion in 'Desktop & Laptop Computers Forum' started by Rick1486, Apr 12, 2003.
  1. Rick1486
    Rick1486
    Feb 22, 2003
    573
    16
    Oxfordshire
    Hi gang - quick question for you all regarding htpc - vplhs10 via dvi.
    I've used powerstrip and set the res. to 1368 x 768 which merrily fills my screen size - however I've now installed igi2, set graphics to high quality throughout (using radeon 9700pro), but when I display on the pj at this res. the piccie doesn't fill the screen, but is pushed over to the l/h/s of the screen at what looks like 1024x768 - this is fine if I am playing it on the 15"flatron monitor also connected via vga to the graphics card but is a let down on the pj. It is also putting me off installing any other games until I get to the bottom of the problem.
    If I select the flatron as primary monitor in display properties and run at 1024x768 then it is perfect on the monitor and is placed in the middle of the pj picture, which is acceptable but obviously not as engrossing as filling the whole pj screen would be.
    I'm sure it's something silly I'm doing wrong.
    Please help!
    Rick
  2. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
  3. Rick1486
    Rick1486
    Feb 22, 2003
    573
    16
    Oxfordshire
    Yeah thanks for that - had a look and saw a lot of Yanks doing mutual back slapping, but in amongst that - if I read it right - it seems that a lot of it is down to the in game resolution and whether or not it allows custom resolutions. The other alternative seemed to be on games based on the Q3 OR Unreal II engine, to manually modify the parameters oneself in the game's system files.
    Please tell me if I'm wrong or if anyone knows an easier workaround.
    Rick
  4. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Spot on.
    No easier way unless the game itself supports widescreen mode such as Serious Sam 2
