resolution CDD question Sony TRV828
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by jessica, Jun 8, 2002.
  1. jessica
    jessica
    If I film using the Sony TRV828 with the megapixel 1070 k CCD and so it claims 520 lines res, and I play back the tape through a cheaper D8 machine, will the improvement in resolution show on the playback in the cheaper machine which has a smaller CCD?
    The cheaper machine claims 500 lines, while the 828 says 520 so will the cheaper machine play back 520 lines or would it just show 500 lines.
    Just a question, shooting some stuff on a friends 828, beautiful video images, noticeably better than my budget D8, but I just want to know if the added res will show up at home when I view the same tape on TV played back in my machine. Would the playback electronics be the same in both machines?
  2. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,115
    Leicester
    +48
    The 1070k CCD would be used for high res stills.
    The cheaper machine will play back it's 500 line spec.
    I wouldn't have thought you would notice any difference in resolution between digital cams,as they are all around 500 lines.
