Resolution advice
Discussion in 'Microsoft Windows' started by chrissyboy6969, Mar 27, 2006.
  1. chrissyboy6969
    chrissyboy6969
    Mar 5, 2006
    45
    Guys i have my mce connected to a 1440 x 900 wide screen pc monitor using normal tv signal which has a resolution of 720 x 576. The picture i am getting from the source is good but its a bit blocky on the monitor. My question is can i do something to my resolution when running tv or is there any software that can do this heard a bit about powerstrip but not sure what these actually do any advice would be good
    I would guess that the problem is because i am showing a source image of 720 x 576 on a screen resolution of 1440 x 900 and it is being blown up like a digital zoom hence the loss in quality, am i right
    Chris
  2. Rambles
    Rambles
    Jul 14, 2004
    10,314
    167
    UK
    +2,085
    So, what happens if you output at 1440 x 900?
  3. chrissyboy6969
    chrissyboy6969
    Mar 5, 2006
    45
    it works fine just a bit blocky, when i downsize the window its in its pin sharp
  4. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Correct. Have a look at TheatreTek or FFDShow. Can't remember which one, but one of them has an upscaling routine to clear up images like this.
    Richie.
