Resizing Image Question
Discussion in 'Photography Forums' started by Paranormalist, Jan 19, 2008.
  1. Paranormalist
    Paranormalist
    Aug 5, 2007
    2,982
    Northern Ireland
    +989
    Hi all.
    Say I have a photo that is 2592 x 3872. How do I resize it to exactly 1280 x 1024?
    I've tried this in Photoshop by selecting Image Size and typing in the amount in the Width & Height boxes but when I type it in one it changes to a different amount in the other to keep proportions. :confused:
  2. dazza74
    dazza74
    Aug 24, 2006
    13,037
    +1,394
    Uncheck "Constrain Proportions" will fix it :thumbsup:
  3. Paranormalist
    Paranormalist
    Aug 5, 2007
    2,982
    Northern Ireland
    +989
    That distorts the picture when I do that. Is there a way to crop it to those exact proportions or anything like that?
  4. stevegreen
    stevegreen
    May 14, 2001
    8,746
    in my Hymer
    +921
    But it will compress the image in funny ways unfortunately. If you don't want that to happen and can afford to lose a bit of the photograph then resize it keeping the constrain proportions checked and then change the canvass size to suit :)
  5. Liquid101
    Liquid101
    Jan 30, 2006
    8,141
    Aberystwyth
    +3,227
    ...and this will give you a distorted image.
    What you need to do is select the crop tool, and in the top tool bar put in your desired dimensions. Then simply make your crop and it will resize it on the fly. Obviously, this will be a slighty different shape crop than your original, but this way alows you to reframe it as you want.
  6. Paranormalist
    Paranormalist
    Aug 5, 2007
    2,982
    Northern Ireland
    +989
    Thank you, steve. Works a treat! :thumbsup:
  7. dazza74
    dazza74
    Aug 24, 2006
    13,037
    +1,394
    Sorry :suicide:
  8. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    I do the following:
    Select All / copy
    Resize canvas to what size you need.
    Paste image and now press ctrl T and resize, remember to hold shift and alt to contain correct scale.
    Now when you save your image as a jpg you will still have all exif info ;)
  9. LeeC
    LeeC
    Sep 16, 2004
    338
    28
    Sunny Manchester, UK
    +29
    There are 2 ways you can do this...
    1) Resize the image so that one value matches the required dimension with the other being too large. So in the case of the image above, resizing the height to 1280 would leave the width as 1912. As 1912 ia bigger than 1024 then the image will be clipped but you will retain the correct aspect ratio.
    2) Create a blank image at 1280x1024 and drag the image to be resized into the new image and rescale it until it fits. Make sure you use SHIFT when you rescale to retain the aspect ratio. Doing this allows you to pan the image round when you get close to the right size so you can scale and crop at the same time. If you zoom out but expand the window, you will be able to see the zoom handles relative to the image better.
    Of course, this is dependant on whether retaining the aspect ratio is important, if not, just turn off the Constrain Proportions and type in the value... as was suggested earlier.
