Residual Current Device for hair drier near handbasin
Discussion in 'Smart Home, Climate Control & Security Forum' started by brains, Mar 1, 2005.
  1. brains
    brains
  2. Fartpants
    Fartpants
    I'd put another mirror on the other side of the room, and keep the dryer away from the basin, RCD or not.
    I wouldn't want to find out if you get a jolt in the tiny time between the fault and cut off.
  3. Dave R
    Dave R
    Jul 14, 2000
    57
    Bristol, UK
    I'd be surpirised if it was legal, RCD or not. Generally all you can have in a bathroom is a shaver socket which uses an isolating transformer.
    But I think you're in the wrong forum really.
  4. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    RCDs are not 100% protection. Apart from the shaver and toothbrush, there should be no other electrical appliance anywhere near a basin :nono:
    Dry your hair somewhere else - or shave your head!
