Quantcast
Resetting Region code on DVD-ROM?
DrPepper
When Run I RPCMAN to reset the region code I
get this message ’ASPI for Win32 not initialised ’
Any know what this means and how do it get this working again?
I have Dell laptop DVD ROM.
thanxs
nutcase_1uk
not sure, but try putting a DVD disc in the drive when you do it. The ASPI layer is the code which sits between teh drive and the software accessing it, and I think it only gets loaded when tehre's something in the drive.
halephil
Hi, check your aspi layer using the utility aspichk.exe found in the file set aspi4all.zip (I just found it through Google at aspif4all.zip ) and use utility aspi4all.exe (also in the zip file) if you need to reinstall the aspi layer.
Regards, Phil
S
Sgt.Colon
Best thing I found with DVDgenie was to copy the winaspi32.dll into the same directory as what the software was installed and then it worked perfectly. :)
DrPepper
Thanx all.
Just found out way it didn't work because
I installed a CD-RW drive few days go and
when I unplugged it the RPCMAN worked:p
DP
Similar threads
