Resetting HD5
Discussion in 'Headphones, Earphones & Portable Music' started by gwhitehouse, Aug 12, 2005.
  1. gwhitehouse
    gwhitehouse
    Hi all,
    I need help really badly, my hd5 has crashed at work and i have no idea how to reset it of fix it!
    Can anyone help me out please as i have a long train journey home tonight.
  2. IanPM
    IanPM
    Jan 12, 2004
    389
    +6
    Pop the battery out, that should clear the crash.
    You might like to consider upgrading to the most recent firmware. Its easy, and there are loads of forum posts about it!
  3. gwhitehouse
    gwhitehouse
    thanks has worked!
    how would i update firmware?
  4. IanPM
    IanPM
    Jan 12, 2004
    389
    +6
    The firmware update is dead easy, its in the HD5 manual that gets installed onto your PC when you put SonicStage on.
    Bascially, you get the .bin firmware file, copy it to the root of the HD5, plug the unit into the mains, and choose update firmware from the initialize menu.
    Its nice and easy, I did it with not problems.
  5. gwhitehouse
    gwhitehouse
    but where do i get the file from?
  6. johann1979
    johann1979
    Feb 18, 2005
    857
    19
    London
    So guys - just to confirm; does the firmware upgrade affect the fact that the volume cap is removed on my current firmware? Also can anyone tell me whether the firmware ONLY fixes the problems or whether there are any other improved features too? cheers :)
  7. IanPM
    IanPM
    Jan 12, 2004
    389
    +6
  8. IanPM
    IanPM
    Jan 12, 2004
    389
    +6
    I've hacked my volume, and the firware upgrade neither reset this or prevents it from happening, as far as I can tell.
    I don't think 1.2 adds much more than a fix for the player hanging. But I'm no expert to be honest.
  9. Hrochnick
    Hrochnick
    Apr 28, 2005
    369
    Brno
    +9
    No, it doesn't do anything more (that've noticed or heard about) or effect the volume hack. But, I don't think it actually stops the crashes, just makes recovering from one easier. It resets itself rather than you having to open the battery compartment. It's happened to me three times since updating the firmware, each time system error 020, same as before the update.
