Resetting bulb hours on Panny AE100 - how?
Discussion in 'Projectors, Screens & Video Processors' started by SanPedro, May 26, 2005.
  1. SanPedro
    SanPedro
    Jan 11, 2001
    4,505
    +505
    I've just replaced the bulb on my AE100 after 4500 hours use :thumbsup: . What i want to know now is how to stop the 'change bulb' lamp from coming on. I've gone into the service menu and over ridden the auto shut down to stop the machine shutting down after 10 minutes.
    Chris
  2. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Chris,
    I don't have the Ae100 manual to hand but there's a procedure in there for resetting the lamp runtime hours - I think if you go to the Option Menu, highlight the Lamp Runtime, hold down "Enter" for about three seconds the "Lamp Runtime" changes to "Time Reset Power Off" or something similar.... If you have this highlighted on the menu and power off the projector (Not press enter again, this just cancels the time reset option) the runtime hours sre cancelled (IIRC your existing hours are moved to one of the "vacant slots" in the familiar green info menu). Maybe this will stop the red light from coming on ???
    Sean.
  3. SanPedro
    SanPedro
    Jan 11, 2001
    4,505
    +505
    Thanks Sean
    will give it a go.
    chris
