Resetting a Yamaha A1 back to its defaults
Discussion in 'AV Receivers & Amplifiers' started by mikauk, Jun 19, 2001.
Tags:
  1. mikauk
    mikauk
    Does any body know how to reset a Yamaha A1 back to its defaults? I used to be able to do it with my old Sony 930 by holding a button or two. I’ve been all through the instruction manually and I can’t find anything I was just wondering if any of you peeps would no how or if it can even be done
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Not that I know, but what's your intention? There aren't that many settings you need to change, so you could do it manually.
    Remember that there is also a memory bank where you can store / recall personalised settings - perhaps even one of those contains the default settings (-> RTFM) ... !?
