Resetting a matsui 1496R TV help
Discussion in 'General TV Discussions Forum' started by wjd, Sep 20, 2007.
  1. wjd
    wjd
    Sep 18, 2007
    3
    This is my 1st post, so I don't really know where to put this question, I'll post it here and can someone please tell me where to post it properly.
    Thank you.
    My sister gave my dm an old tv we've set it up but they don't remember the 3 number password, it's only in her bedroom but it would be nice if she could turn the tv over,
    It's a matsui 2096R - 1496R
    I've been looking on google and found this
    Matsui 1496R Clearing Pass Mode Conect sw between pins 4 & 17 on r/c chip. Sw on using R/C, select chans with passcode no. Hold sw down for 2 secs until chan clears & pic returns
    Does anyone know what it means, I haven't a clue. It's a shame as it's a nice little tv, hopefully we can get it too work, I can't even tune in sky without the password, the other ones are tuned in but you can't turn onto 1 or 2 without it.
    Please help. It's driving me mad, I hate to be beaten by thing's like this. Where can I find the answer to fix this.
    Thank you.
  2. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
    Moved to crt forum.
  3. I remember when
    I remember when
    Jun 29, 2007
    346
    Kent
    +9
    Hi from the instructions you open the remote control unit and bridge a connection between pins 4 and 17 on the IC when you are on the locked channels for 2 seconds
    Make sure you are pointing the remote towards the TV when you bridge the connection and the remote will send an infrared code and unlock the TV do this on all effected channels use a piece of wire it will save you soldering a switch etc Then put the remote back together Regards Mike
  4. wjd
    wjd
    Sep 18, 2007
    3
    Thank you Mike, gave it a try, and it worked, I didn't understand quite what you meant, but did what I thought you meant and it did it first time.
    Thank you very much, you've saved us from buying a new bedroom tv.
    Wendy x :thumbsup::thumbsup::thumbsup:
  5. I remember when
    I remember when
    Jun 29, 2007
    346
    Kent
    +9
    Hi Wendy your more then welcome
