Resetting a Denon amp/rec. Anyone know how?
Discussion in 'AV Receivers & Amplifiers' started by Bristol Pete, Jan 11, 2005.
Tags:
  1. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    Anyone know of a quick way to reset a Denon amp?
    Have scoured the manual but cant find it...... :confused:
    Was easy on my Sony, just simply press on with a certain button on the facia pressed down..... :lesson:
    Thanks,
    Captain Benefit :smashin:
  2. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    At The Track or Melbourne Victoria Australia
    +3
    Model would be handy :lease:
  3. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    The very model that you recommended to me Oz, the 2805.
    Thanks,
    Captain Benefit.
  4. S H A D O
    S H A D O
    Mar 16, 2001
    10,373
    United Kingdom
    +1,747
    It should be in the manual under Initializacion of the Processor. Usually involves holding down two buttons on the front panel whilst turning the power on, the display flashes while you hold the buttons and resets the amp. Bear in mind this will reset everything to the defaults.
    Just checked. Hold down the Input Mode and Analog button on the front panel whilst turning the power on. :)
  5. anotherdavid
    anotherdavid
    Nov 30, 2004
    38
    it's on page 52 of my manual - as Jase says " Initialization of the Processor" - there's a heading in the contents
    (and the award for the worst user manual ever goes to .....AVR-2805! really they should just ask someone if their translation makes any sense before going to print...rant over)
