Reset V+HD to scart output
Discussion in 'Cable TV & Virgin Media TV' started by bferbrache, Nov 27, 2010.
  1. bferbrache
    bferbrache
    Apr 26, 2003
    2,017
    63
    Leicester
    +131
    I have a Samsung V+HD box that I want to use via the scart output but its set to output via hdmi at the moment. Can anyone advise how to reset box so it outputs via scart?
    Brian
  2. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    Try the menu 'picture' settings. It's pretty self explanatory. When the box was installed by Virgin there should have been an instruction manual sent to you.
  3. bferbrache
    bferbrache
    Apr 26, 2003
    2,017
    63
    Leicester
    +131
    Thanks for the help, I perhaps didn't make myself clear, I moved my box upstairs to use with my crt telly and couldn't see the menu. I was looking for advice on how to reset the video output without taking the box back downstairs and pluggging it back in to the HDMI connection there.
    Done that now though so I'm all sorted. I'm not sure what the rest of your comments are about though
    Brian
  4. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    Apologies. But you were asking a fairly fundemental question without giving the full reason why you wanted to change the outputs.
