Question Reset a Minix Neo U1
Discussion in 'Video Streaming Boxes & Services' started by Rigsby123, Aug 24, 2018.
Tags:
  1. Rigsby123
    Rigsby123
    Dec 22, 2008
    30
    Firstly, apologies if this is answered elsewhere, if so please direct me.
    I've had a Minix Neo U1 for some time but recently I can't access the "Settings". The screen flickers & just comes back to the main selection.
    Is there a way to reset the box to Factory settings ?? Obviously I can't get into the "Settings" to do it. I've googled it and have yet to find an answer.
    Alternately, if there's another way to get into "Settings" that would suffice too.
    Thanks.
  2. Jamie
    Jamie
    Jun 27, 2007
    5,395
    2
    Harrogate
    +1,405
    There's a reset button underneath you can push with a pin.
    With the U1 turned off press the rest button and hold it in, press the power button and keep the reset button held for 10 seconds. This should get you to the recovery menu which has a factory rest option.
  3. Rigsby123
    Rigsby123
    Dec 22, 2008
    30
    Thanks Jamie. I'll give that a whirl. Many thanks.
  4. Jamie
    Jamie
    Jun 27, 2007
    5,395
    2
    Harrogate
    +1,405
    If you have any problems I found the Minix Forums to be very useful. Although I don't seem to be able to access them right now.
  5. Rigsby123
    Rigsby123
    Dec 22, 2008
    30
    That's right. I've checked the last few days and also a while ago. Dunno if they exist anymore. Would be a shame if they've closed down considering the great reputation their products have.
  6. pxr5
    pxr5
    Dec 28, 2005
    748
    46
    Blackpool
    +107
    On FB they are saying there's an issue with the forums and are trying to get back online ASAP.
  7. Bulgan
    Bulgan
    Oct 15, 2017
    10
    Wexford, Ireland
    Hi Guys. I am having the same problem. Anyone know if there is away around getting into settings without having to reset back to factory settings? Thanks
  8. EpimetheusX
    EpimetheusX
    Sep 2, 2018
    2
    4
    UK
    Hi all, factory reset doesn't fix it and the minix forums seem to have been shutdown. I contacted Minx directly and they emailed me a new firmware but sadly this didn't fix the problem. After a factory reset settings does work but as soon as you update any apps such as the built in ones or add any new ones the problem returns. I've informed Minix of this today and wait to see what happens.
  9. ieswideopen
    ieswideopen
    Sep 3, 2018
    Tallahassee
    Issues like this are rarely a problem with the firmware, or the box, but a software conflict. In this case simply roll back the update on your "contacts" app and you'll get the settings back.
  10. EpimetheusX
    EpimetheusX
    Sep 2, 2018
    2
    4
    UK
    Yes. I received an email from Minix today telling me to uninstall contacts back to the factory version and it worked .
  11. midelpo
    midelpo
    Sep 8, 2018
    italy
    I, Could you pass me the firmware that provided you with Minix?
  12. NicSchm
    NicSchm
    Sep 15, 2018
    Montreal
    Rolling back contact also fixed it for me. If anybody has a firmware update that fix the issue, I would also be interested. Thx!
  13. Pesiw
    Pesiw
    Sep 15, 2018
    Mars
    How do you "uninstall contacts back to the factory version"?
  14. RickiRicardo
    RickiRicardo
    Sep 18, 2018
    Edmonton
    Same thing is happening to me on one of my Minix boxes and it’s super annoying. Ever since I did some updates. How do you roll back contacts??
  15. MattelloCR7
    MattelloCR7
    Sep 22, 2018
    4
    Italy
    Hi guys,same problem for me from 48hours... what is the procedure to Roll back contacts?thank you in advance
  16. Johnyfriend
    Johnyfriend
    Sep 29, 2018
    2
    London
    Awesome this helped.. I also my minix a3 remote started having blinking microphone lights and killing the battery and dies every 3 days. I u installed Google assistant updates and that fixed it..
  17. testshoot
    testshoot
    Sep 30, 2018
    2
    Land of Enchantment
    When I try that, nothing happens. To make matters worse, the Minix is not responding to the remote, even tried new batteries. Like others, things went from bad to worse after doing an update...it would boot up, go to the ES Explorer screen, and restart.
    Before that, when I had tried to do a Minix firmware update, it would get stuck in restart mode...forever....had to unplug it to get back to the home screen.
    I only have the box for Kodi. I installed Kodi on my Fire TV and maybe that is the way I will go, making the Minix another piece of worthless electronics. I would like to use the Minix, but if I can't reset it, can't get it to recognize the remote, I am stuck??
  18. Johnyfriend
    Johnyfriend
    Sep 29, 2018
    2
    London
    Did you rolling back Contacs and Google assistant? It fixed a lot of issues for me including sound, remote and settings
  19. testshoot
    testshoot
    Sep 30, 2018
    2
    Land of Enchantment
    Hello, Wasn't able to communicate with the remote and then for some reason it work. Since I was never able to do system updates I thought I would start from scratch and finally got it to go into recovery mode so I did a factory reset, then once up, I did a system update, but didn't do an Google update. I was stuck on an old Kodi and now I was able to update that. Will see now if I prefer Kodi on the Minix vs. on my Fire TV which I installed in the interim. Thanks!
