rescan music folder
Discussion in 'Microsoft Windows' started by johnbhoy#, Jun 25, 2005.
  1. johnbhoy#
    johnbhoy#
    Jun 25, 2005
    23
    I have the mce installed but i did a self build and i did not get the remote so i am using a hauppauge remote. I am basically looking to rescan my music folder again as it does not appear to have picked up all my albums. I see the instuctions state press the info button on remote control when in Music section but this is not available to me as it dont have the standard MCE remote. Is there any work around to do this or am i just being a bit dumb.
    Two options basically. Can i program the "info" button into my hauppauge remote (silver one) or is there a manual way to rescan by clicking the mouse.
    Many thanks
  2. lisag
    lisag
    Jul 14, 2004
    5,681
    Essex
    +333
    I think the right mouse button does the same as the remote 'i' button...but might be wrong - worth a try anyway..
  3. stuartmc
    stuartmc
    Oct 20, 2004
    203
    16
    Reading
    Easiest way is to use Media Player 10 to rescan your music and then MCE should see it.
