mistryn
forgive me if this has been asked before but i have spent the last hour or so searching this section of the forum and gone round in circles
i have just bought myself a 37" samsung l87rdbx model which has a freeview built in. i dont have access to an external aerial and will require help in deciding which one would be the best for me and where to get one from
from what i gather indoor aerials are a bit hit and miss so decided to go down external route. installing it will not be a problem just decidng which one and how to determine which way it to face to get good signal im having difficulty
this is my post code - dy1 2rb, i have looked on the following websites and put in the post code but the information is just going over my head. can someone translate what type of aerial will i need?i have checked the freeview webiste and that says i can get all the freeview channels.
http://www.wolfbane.com/cgi-bin/tvd.exe?DX=L&HT=10&OS=dy12rb
http://www.tellyaerial.34sp.com/ta....NGR=&transmitterNumber=10&Submit=Show+Terrain
something like this will it be suitable?
http://www.screwfix.com/prods/30515...ixings/Labgear-TV-Aerial-High-Gain-48-Element
or
http://www.screwfix.com/prods/75506...gear-Mega-Booster-Amp-Outdoor-TV-Aerial-Cable
i forgot to mention that i will be fixing this to the side of the house as access to the chimney is restriced, dont know if this will make a difference?
help
or
help
