Require HDMI DVD player
Discussion in 'Blu-ray & DVD Players & Recorders' started by FaxFan2002, Jun 14, 2005.
  1. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,413
    63
    Andover
    +157
    I am going to upgrade my panny 6 screen to a pv500, which will have a HDMI input. My old faithful Denon 2800 MK2 will need upgrading - I want something that is of the same quality, the obivious is the 2910 but I'm not so sure. Suggestions anyone?? I had a Harmon Kardon before I and quite liked that.
    Thanks.
  2. FlyingBig
    FlyingBig
    Apr 11, 2004
    545
    Lisburn
    Samsung HD950 would be a good choice. You must be aware of Macroblocking when using HDMI through these new dvd players which i am sure the samsung is free of as it uses a different chip from the Denon/Panasonic HD dvd players. Do a search for macroblocking to fully understand it but basically you will get breakup (like pixelation) during fast moving scenes so its best avoided and i am going to put my money with samsung and hope for the best.
    P.S. my PV500 arrived yesterday and i am very happy, a few minor problems but i am confident i can sort them out but otherwise a great tv, best i have bought in a long time.
  3. greyhorse
    greyhorse
    Apr 16, 2005
    447
    I was looing at getting the 850 for the Divx playback is it worth waiting for the 950 ???
  4. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    Unless there is something wrong with the Denon then I would not bother upgrading. Seems little point in just getting one wit HDMI just for the sake of it. DVDs are only SD anyway and the scaler in the samsung is not going to be better than the scaler in the screen.
    HDMI doesn't necessarily give a better picture!
  5. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,413
    63
    Andover
    +157
    Parklife, thats the opposite to what I've heard?!? I'd have thought a digital connection would give a better picture than a analogue (component) connection.
  6. PCNutty
    PCNutty
    Jun 9, 2005
    162
    Leicester
    +10
    I have just hooked a Panasonic - S97 up to ny projector via HDMI & the picture quality suprised me. when i first decided to buy a projector i didn't think i would get a picture so good. This DVD Player is fully loaded with every connection you can think off
  7. FlyingBig
    FlyingBig
    Apr 11, 2004
    545
    Lisburn
    Samsung 950 is out already so no need to wait other than for availability.
  8. FlyingBig
    FlyingBig
    Apr 11, 2004
    545
    Lisburn
    What projector you got?
  9. FlyingBig
    FlyingBig
    Apr 11, 2004
    545
    Lisburn
    Yes it does, any expert will tell you that.
  10. PCNutty
    PCNutty
    Jun 9, 2005
    162
    Leicester
    +10
    Panasonic PT-AE700
  11. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    I am afraid it is not quite as simple as that. It all depends on the player. I would say that a Denon 2900 will give a better picture through component than a £200 player using HDMI. The screen is going to rescale whatever you send it anyway to match the native resolution of the screen.
  12. thornton
    thornton
    Apr 18, 2005
    263
    +10
    There is a little bit of unjustified claptrap in this thread. I would say there is NO point in discarding the Denon JUST for the sake of getting HDMI. I have had the Panny S97 running with a 37PV500 for a few days now on both component and HDMI and have settled on using the component. There is, having tried about 15 DVDs, nothing much between the two, with component being a bit more forgiving on some older discs.
    With a more another or more expensive DVD player the HDMI might win or the component might. Although my experience is a bit limited, I am beginning to wonder what all the fuss about HDMI is. I think I will trust my own eyes rather than hypothetical "experts".
  13. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    Thornton I am with you on this one. HDMI has been given a lot of press and if you compared 2 top end players one with component and one with HDMI I would agree that the HDMI woudl probably give you a better picture.
    If you compare a top end player with component and a bottom end payer with HDMI then the component would more than likely give you a better picture.
    Anyway you have one HDMI input so why waste this on an SD Source? Stick with the Denon via component and wait til Hi-Def DVD players come out or Sky Hi-Def.
    Back to the original Q. Unless you need to upgrade I would hang on until Hi-Def DVD comes out.
  14. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    I agree with Parklife, HDMI being "all digital" DOES cut down on a small amount of picture noise, and give Hollywood piece of mind for higher resolutions, but it's not the means to an end. It should look better most of the time though.
    I think the main reason Component is dying an early death is to satisfy Hollywood executives paranoid about copy protection.
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    If you search you will see i often try and stop people wasting money unnecassarily on HDMI kit when there is no need.......But its your money feel free I'll offer you £50 for your useless out of date extinct denon.............(as long as its black)
  16. lnewey6
    lnewey6
    Nov 10, 2003
    196
    derbyshire
    +3
    if you pop over to avland they have got loads with hdmi on pioneer dvd player as low as 150.00 got to be a bit of a bargain
  17. gingerone
    gingerone
    Dec 10, 2002
    2,556
    +383
    You'd have to be mad to swap a class player like the denon for the samsung.
    You will be seriously peeved if you do.
    I noticed a better quality picture using hdmi over component but I dare say that the component ouptut on the denon would blow the samsung away anyway.
  18. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    :confused:
    If Pioneer did a player with HDMI/DVI for that price i'd be there! Cheapest is the 668 at 600 quid. Don't be confused by the graphics - it may show a HDMI or DVI socket but if it has a zero underneath it, it means there isn't one..
    ...PJ :)
  19. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    I'd love to try the Denon 1910 to see how it looked via DVI...PJ :)
  20. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,413
    63
    Andover
    +157
    HD,
    It's gold, and I'm seriously peeved that gold has been dropped (I have a matching 3803)! Anyway I'll see how I get on with component on the useless out of day extinct denon! Thanks for all the feedback interesting stuff.
  21. cjp123
    cjp123
    Nov 2, 2004
    77
    I do not want to waste my money but I have just bought a 32" Samsung Lcd and it is fantastic. I have a pioneer 565a DVD player and I connect this using a s-video cable as I do not have a componant cable. The picture quality is fine but I a worried that it can be better. I was going to buy the 950 when it came into stock as it includes a free HDMI cable but is it really worth it ? I have a lot of both R1 and R2 disks so it needs to be region free but will I be wasting my money or will this player show a sig diff then my pioneer ? What HI-FI rated the 745 as a 5* player above the one I have as mine so there must be some difference ? Please let me have you views before I waste my money.
    Thanks in advance.
  22. dvdchild
    dvdchild
    Aug 10, 2004
    5,632
    2
    +423
    [post removed by admin. We have classified advert forums for this kind of thing, dvdchild. Please post adverts there.]
  23. batty
    batty
    Nov 22, 2004
    229
    Southampton
    +27
    :hiya: I would definatly give Component a try, i use componet to feed my plasma and the quality is great. I cannot believe the quality can get much better until we actually have high def discs to play.
    BTW you will probaly see an improvement with a good scart and the dvd player set to RGB. S-video is generally the poorest quality connection.
    Hope that helps
