Request for advice on upgrading to a new amplifier/receiver
Discussion in 'AV Receivers & Amplifiers' started by antz, Aug 13, 2003.
  1. antz
    antz
    Aug 13, 2003
    307
    Brum
    +8
    Hi All
    I need some help.
    I bought my current surround system back in 1993, so you can imagine it's time to upgrade to digital.
    However, I'm hoping I can keep my speakers which are:
    L/R: KEF Reference 103/4 floor standers (impedance 4 ohms)
    Centre: KEF Model 100 (imp. 6 ohms)
    Surrounds: KEF Model 70S (imp. 6 ohms)
    I have an extra pair of the 70S's for the additional surround channel/s.
    My current amp is a Yamaha DSP 1070, at the time it was the top of the range, but compared to a friends Denon, I've always found the sound too soft for a/v, but very good for stereo music.
    I'm looking for an amp costing below £1000 which will drive these speakers adequately and have the latest digital surround formats. Thanks for your help and advice in advance.
    Antz
  2. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    loads that will fit your needs from Denon, Onkyo, Pioneer, Sony, Marantz + more you'll not get a definitive answer here as each has it's supporters and detractors. Find a few dealers and have a chat with them - Sevenoaks and Audio Excellence have always been helpful. Get it down to a shortlist, use the search funtion (top right) to find all the waffle we've spouted in the past on the bits of kit you're interested in & get a demo & if poss buy on approval to make sure you're happy.
    To get you going - I'm looking at the Onkyo 701 but I might wait until I can afford a bit more for the Rotel RSP1066
  3. antz
    antz
    Aug 13, 2003
    307
    Brum
    +8
  4. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,917
    38
    UK
    +7
    Definately demo the Rotel RSP 1055 reciever. It may be a little outside your budget but it's the best thing I have heard under 2 grand.
  5. Gatto
    Gatto
    Try and check out the NAD T762 it will surely drive your speakers with Ease, lots of decoding, connectivity and great internal AMps.
    but as always have a listen and let your ears do the work for you!
