Reqd: 120 cm, 2 shelf, glass av unit
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by Triggaaar, Jul 19, 2004.
  1. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,207
    +1,190
    I'm after something like the Optimum AV200 for my 50" plasma. Unfortunately, the Optimum range (as well as everything else I can find) only comes 110cm wide, but I need it to be 120.
    Any ideas?
  2. bobbypunk
    bobbypunk
    Specteral stands S133,S134,S120 are all 120cm
  3. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,207
    +1,190
    Thanks. The only things I can find on specteral with Google are to do with murder, the undead, and a link to another post in this forum where you were recommending them as a projector stand.
    You mean Spectral :)
    I'll check it out.
  4. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,207
    +1,190
    Ah! Annoyingly close. The 120cm units are 3 or more shelves, otherwise perfect.
    Any other suggestions?
  5. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,207
    +1,190
    I'm still struggling here. Could go for the Spectral S120, and just use 2 shelves (if that's an option). Or maybe the Alphason AD3/105 (again removing the top shelf).
    Any other ideas before I have to go for something that's not quite right?
