Replacing Z2, any install issues?
Discussion in 'Projectors, Screens & Video Processors' started by zAndy1, Aug 21, 2004.
  1. zAndy1
    zAndy1
    Nov 26, 2002
    19,793
    2
    5
    163
    +6,952
    Hi folks,
    I've currently got my Z2 ceiling mounted in the centre of the screen but using quite a bit of vertical lens shift (don't think I'm using much if any horizontal lens shift). Obviously the screen can't move and neither can my ceiling mount so will I be safe in assuming that if I replace the Z2 with another projector (e.g. Themescene H77) that I'll still be able to get it lined up ok with my screen without compromising picture quality? I know the H77 has vertical lens shift but no horizontal so I guess that's the main issue really. Has anyone else done something like this and come across problems, just want to know in advance that's all!
    Cheers,
    Andy.
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Andy,
    You should have no problems substituting the Z2 with a H77 with its vertical lens shift.
    Should be a good upgrade judging by the comments on the AVS Forum.
    Jeff :rtfm:
