Replacing the speaker in a subwoofer
Discussion in 'DIY Speaker & Subwoofer Building' started by dUnKle, May 1, 2016.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,620
    +2,493
    I have a Rel Q100 subwoofer
    I've owned it from new for many a year (at a guess must be around 15 years)
    It's survived numerous moves from room to room, various travels upstairs, periods of storage and noise moves
    I know it's not cutting edge but it was one of the first proper pieces of home cinema I purchased
    Anyway, today I notice it really was not sounding great and removed the grill to see the actual speaker appears to have perished
    It just looks worn out and has torn / come away around the outside of the cone (the rubber / material bit around the edge)
    So can I replace the speaker and this bit ?
    I fancy a project and like to get it working again
    What do I need to buy ?
  2. dUnKle
    dUnKle
    Jan 1, 2001
    15,620
    +2,493
    Actually seems like this may be what I need
    REL Q100E Replacement
    Before I order however can I buy anything better that may even improve the sub ?
  3. dUnKle
    dUnKle
    Jan 1, 2001
    15,620
    +2,493
  4. stevelup
    stevelup
    Aug 13, 2002
    6,642
    Swindon
    +1,167
    You can't just put a random driver in a subwoofer. They are usually matched to the cabinet. I'd be very much inclined to replace it with the correct one otherwise you might well make things worse rather than better.
  5. dUnKle
    dUnKle
    Jan 1, 2001
    15,620
    +2,493
    Thank you
  6. IronGiant
    IronGiant
    Jun 7, 2003
    63,613
    +42,694
    Stick with the original replacement replacement :)
  7. dUnKle
    dUnKle
    Jan 1, 2001
    15,620
    +2,493
    Cheers. I shall place an order
