Replacing the bulb in this under cabinet light.
Discussion in 'General Chat' started by TylerDurden, Feb 23, 2018.
  1. TylerDurden
    TylerDurden
    Nov 6, 2005
    4,133
    +616
    So I'm looking to replace the bulb in this under cabinet light. I can see any obvious way to access and replace the bulb and don't want to force it too much in case I damage it
  2. gg13533
    gg13533
    Mar 18, 2005
    771
    96
    +517
    Is there not a slot for a screwdriver to lever off the glass or the chrome surround?
  3. ufo550
    ufo550
    Sep 20, 2014
    1,401
    113
    Oxfordshire
    +769
    As above, the glass & its chrome surround, will pull out of the triangle base. Once off, you'll see how to replace the 'bulb'.
  4. IronGiant
    IronGiant
    Jun 7, 2003
    65,179
    +44,851
  5. SteakAndCake
    SteakAndCake
    Nov 22, 2012
    6,638
    +6,432
    I had these in our old kitchen.
    The whole round part clips into the triangle surround and can just be pulled out (depending on wire length). It has metal clips.
    Then to get to the bulb, around the edge of the frosted glass is a small metal spring ring. Clip that out and the glass falls out (careful you don't drop it on the floor).
    Under the glass is a standard G4 type Halogen bulb you can just pull out and push in the new one.
  6. SteakAndCake
    SteakAndCake
    Nov 22, 2012
    6,638
    +6,432
    That's exactly what holds the glass in.
  7. ufo550
    ufo550
    Sep 20, 2014
    1,401
    113
    Oxfordshire
    +769
    Haven't seen that type myself. Here's how to put one up, you can see how the centre part fits into the triangular part;
    Biard Triangular Under Cabinet Light...
