Replacing Speaker Terminals
Discussion in 'Home Cinema Speakers' started by BrianC, Jun 20, 2005.
  1. BrianC
    BrianC
    Jan 20, 2003
    2,199
    +101
    I'm after a decent supplier for speaker terminals to retro fit into my Wharfedale Evo 8s after my daughter managed to knock one of them onto the floor snapping two of the terminals right at the middle of the hole for the speaker wire :mad:
    I've had the back off the speaker and it seems to be easy as pie to replace the terminal but I'm having trouble finding decent replacement terminals, the ones on the speakers are gold plated, pretty fat and quite long (about 30 mm), suggestions welcomed.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
