Replacing speaker grill cloth on genie's
Discussion in 'Home Cinema Speakers' started by Neil Fellows, Apr 20, 2005.
  1. Neil Fellows
    Neil Fellows
    Apr 6, 2004
    301
    Hi there. Has anyone tried replacing the speaker grill cloth on their Genie's to a different colour? I'd like to replace the black with a magnolia to make them more discreet when wall mounted, but was wondering about the best way to do it? I may try giving Mordaunt-Short a bell to see if they can sell me the bare plastic frame with no cloth yet glued on, before self destruct mine.
    Also, anyone know a good place that sells speaker cloth in different colours?
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,196
    2
    +3,669
    I might as well start reading up before you you call me then :laugh:.
  3. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Radiosilks is the place. I'm afraid I don't know their web address but a search should find them.
  4. Neil Fellows
    Neil Fellows
    Apr 6, 2004
    301
    ok, how much is it gonna cost?!
    Taking a quick look at mine, it looks glued on all round, so I was going to rip it off, sand it down and (try) to apply the new cloth when I get some. Would it be possible for me to purchase the basic 'frame' before the cloth goes on, or do you buy them in ready made?
  5. Neil Fellows
    Neil Fellows
    Apr 6, 2004
    301
    Thanks Bernard, I'll do a quick search.
