Replacing Sony DAV-S300
Discussion in 'Home Cinema Buying & Building' started by ripkord, Jun 12, 2004.
  1. ripkord
    ripkord
    Jun 7, 2004
    594
    43
    Glasgow
    +107
    Hi guys/gals, I want to replace my Sony with a similar all in one system.
    Its for a medium sized livingroom (the 25W (I think?) satellites seem adequate on the system I have)
    I like the Sony fine, I just really would like a digital optical in for the likes of the PS2/Xbox games that are 5.1 and Sky+ should I get it.
    I read a good review of the Pioneer DCS-313 and having looked though some posts here I see it has had a very mixed reception. My budget is going to have to be less that or around £250 - so the Pioneer seems like a good deal, but some of the things I have read on here have put me off slightly.
    Can anyone with experience of both sytems (or a similar year 2000 Sony) please let me know if it would be worth my while upgrading... I'd like to hear an Improvement as well as gain an optical input....
    Other systems and links to specs/pics/reviews would be most welcome :)
  2. watchmaker
    watchmaker
    Aug 22, 2003
    168
    +15
    If you're thinking about connecting a few different sources via optical (PS2, Xbox, Sky+) would you not be better with an amplifier with a number of these inputs?
    Does anyone know if you can use the speakers from the DAVS-300 with a different amplifier to save you from buying new speakers?
  3. ripkord
    ripkord
    Jun 7, 2004
    594
    43
    Glasgow
    +107
    lol you might be onto something there.... lol
    scares me how stupid i can be sometimes... :D
  4. watchmaker
    watchmaker
    Aug 22, 2003
    168
    +15
    :laugh: I wouldn't put yourself down too much.
    It's always better to ask here first and then buy the right thing than to stupidly buy the wrong thing.
  5. 2pods
    2pods
    Dec 8, 2003
    203
    +6
    I'd like to know if it could be done with the Aiwa HTV90's speakers also
    See my post in the Aiwa thread
    Peter :rolleyes:
