Replacing SkyHD+ hard drive?
Discussion in 'Sky Digital TV Forum' started by onkyoman, Jan 5, 2012.
  1. onkyoman
    onkyoman
    Jul 26, 2011
    130
    Hey there,
    Right, well got a SKYHD+ box, just the regular navy blue one... Starting to run out of space all the time so needing to upgrade it to 1TB or more if possible just wondering though is it just a matter of replacing with any 2.5"/3.5" HDD from the net just like I would with a pc? Or is there more to it?
  2. logiciel
    logiciel
    Feb 2, 2008
    52,971
    UK
    +5,718
    There's more to it, and a search of the forum will find you many posts about it.
  3. mrmt32
    mrmt32
    Aug 24, 2006
    56
    +26
    If you have any HD box except the Thompson (the model is written on the label on the back of the box) then drives 1TB and below can be directly replaced, you just have to run a "full system reset" after swapping the disks over (note that obviously any recordings on the old drive will not be on the new one).
    If you try and do this for a drive over 1TB in size, then it will only be formatted to 1TB. Drives of up to 2TB can be used (for non-Thompson boxes) if they are first formatted using a PC (special software must be used as Sky drives use a proprietary format), this will also allow you to copy over any old recordings.
