Replacing Seleco SVP400HT Lenses
Discussion in 'Projectors, Screens & Video Processors' started by DexS, Sep 4, 2003.
  1. DexS
    DexS
    has anyone had experience changing the lenses of SVP400HT to HD145 ? The current Delta Tac ones are said to be inferior optical wise. I would like to know how easy or difficult the process will be.
    Dex
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    It couldn't be simpler. There will be 4 screws in the corners just undo them. make a carfull note of where the spacers go.
    (which are small pieces of aluminum).
    The HD145 will just go back in place. You can either do them one at a time or all 3 together. Make sure you get the focus lock screws at the bottom or you will have to start over.
    After very careful refocus the back focus knob does the centre the front does the edges/corners. Lock off the lens. Almost certainly you will have to reconvergebut the geometry should be good.
