Replacing Infocus Screenplay5700
Discussion in 'Home Cinema Buying & Building' started by seajayj, Jan 8, 2012.
  1. seajayj
    seajayj
    Nov 28, 2011
    7
    Hi Folks:hiya:
    Your advice please, I have a ceiling mounted Infocus Screenplay 5700 which has power & componant cables in built into the walls, I think I now need to replace the projector as it no longer receives incoming signals from my devices:(,
    I am having it looked at but wondered what projectors currently on the market would provide a direct replacement, remembering I need the new one to accept componant inputs, HD,and give the same throw?? as it will be mounted in the same position, there are so many on the market and prices are so different, my budget would proabaly be around $1000, any suggestions much appreciated:thumbsup:
    All my devices to connect, av receiver amp, with componant output, all other devices feed into the amp.
    cheers
    seajay
