Replacing a stolen CD/radio...how easy?
SanPedro
Joined
Jan 11, 2001
Messages
4,578
Reaction score
585
Points
1,041
Just had the single shot CD/radio nicked out of my car.
Pointless claiming as I don't have a protected no claims and the excess is £100.
How easy is it to fit a standard unit like this? Or should I go to a dealer? Or will an auto electrician be able to do the job cheaper and just as well?
Finally any suggestions for where to get a cheap CD/radio from, possibly 2nd hand even - and can anyone recommend a dealer in West Yorks/East Lancs area.
Thanks in advance
CL
What car is it for Chris?
Most modern or german cars are fitted with ISO plugs making changing head unit a piece of p***.
Try someone like www.mcs-direct.co.uk for cheap head units.
Cheers, Mylo
Thanks Mylo
It's for an Alfa 156 thats 2 years old. There's just a great big hole in the dashboard where it used to be and a couple of sets of wires plus one that looks like a phono plug.
Chris
The BIG PROBLEM With Your Home AV System EXPLAINED
Back
