replacing a faulty remote?
Discussion in 'AV Receivers & Amplifiers' started by raymondod, Feb 8, 2009.
  1. raymondod
    raymondod
    Nov 18, 2008
    193
    stoke on trent
    +3
    Hi, sorry to bother you all. I have recently purchased a Yamaha RXV 620 amp from the forum and unfortunatly the remote no longer works.
    Can anyone reccomend one of those 'all in one' remotes that would work with this amp ? ( preferably under £10 :thumbsup:)
    ryan
  2. William YZF-R1
    William YZF-R1
    Nov 5, 2008
    4,255
    +536
    Have you looked on Ebay for a replacement 2nd hand Yamaha remote?
    I was watching an auction for a remote for my receiver to use as a second remote/spare but missed the end of the auction and it only sold for approx £5
  3. raymondod
    raymondod
    Nov 18, 2008
    193
    stoke on trent
    +3
    Thanks for your reply william. Ive had a quick look on ebay but had no joy in finding the remote.
    Would the remote have to be the exact model, or would i get away with using a different yamaha one?
    Thanks again
    ryan
  4. sp_harris
    sp_harris
    Feb 13, 2006
    582
    +60
  5. raymondod
    raymondod
    Nov 18, 2008
    193
    stoke on trent
    +3
    Thanks for your reply sp_harris.
    Unfortunatly I cant spend anything over £15 on a remote at the moment.
    I think I shall pick up a cheapo from ebay and see how i get on with it.
    Thanks again
    ryan
