AMc
I can't really find anywhere appropriate for this but I'm going around in circles
so perhaps you kind people can help?
I have a bathroom mirror with a circular T5 tube behind it.
We fitted it in 2009, I finally worked out how to remove the front and get at the tube but I'm struggling to find a direct replacement.
Habitat have discontinued it and I can't remember what it's called anyway.
The fitting says T5 Max 32W
The tube says "Jinling" or perhaps "Linling" and "FCL 32W/T5 2700K"
The tube seems to have a 2GX13 fitting
The overall diameter is about a 240mm internal 270mm external (it doesn't seem perfectly circular)
I'm struggling to find anything online. It's also not clear if when sites are describing their circular tubes if you measure the internal or external width - guessing external?
None seem to match what I have and there are clips in the fitting that the tube has to fit in.
I'm also struggling to find 32W tubes warm white tubes and I don't want anything dimmer.
Here's some pictures, any help appreciated!
