So, one of my Panasonic plasmas has finally died and it looks like it's time to replace the primary one and move that into the secondary room. Both are 42".
I've been very happy with the picture and never really had any problems with motion while watching football. Also, the sound is good on those models.
Now, it would appear that OLED is the way to go, but at £1000 at least, I don't know if I can go that far.
Mainly, I want good picture quality like the plasmas.
Please answer the following questions:
Will you be buying and using an UHD Blu-Ray player? No
Netflix? No
Amazon? Yes
Apple TV. Yes
Catch up TV? Yes
HDR games consoles? No....secondary tv will have an XBOX
PC usage? No
DVDs? No
FHD Blu-Rays? What?
Sky, BT or Virgin? UHD or HD? Sky, SD and HD, probably 40/60; we only have the free HD channels
Budget is anywhere between £350 and £500-600 but I really want a good picture and the motion handling; I do not want to see blurring watching football. A friend of mine had a 55" curved Samsung I think, only a few years old, and on football it was awful!!
Help!
- What are your sources going to be? For example:
Netflix? No
Amazon? Yes
Apple TV. Yes
Catch up TV? Yes
PC usage? No
DVDs? No
FHD Blu-Rays? What?
- Movies, sport, console games, PC use in percentage? movies, tv series, sport, football
- How close can you view the TV? 11ft
- Do you need to view the TV from the side or only straight on? Slight angle....20-30% We have 2 sofas at about the same angle
- What conditions do you view in? During the day? At night with lights on? In the dark? A mixture. Evening with lights on ideally.
- What TV are you currently using and what are expecting to see upgrading to a new TV? Bigger screen for more of everything, good motion handling, good darks and detail.
- Motion - Are you interested in being able to use motion enhancements on your TV to reduce judder and/or reduce motion blur? Both frame interpolation and frame insertion let you do this, read more about it here. They both have their upsides and downsides, so read carefully.
Help!
