replacement wiimote straps
fizzgog
hi folks. i got a helpful message from amazon today with a link which enables me to get replacement straps for my controllers.
the only problem is that when filling out my address, there are only 6 spaces in the post code field and my post code has 7 digits/letters
it is also a required field so i cannot leave it out.
has anyone else had this problem and found a way around it?
thanx for your time
pete
Bigmonty69
I had the same problem but just put in as much of the post code as I could. As long as you have the rest of the address there shouldnt be any problems.
fizzgog
thanx for the fast replies, i will enter what i can.
..pete
secretagent2
i ordered mine, and could only put 6 digits of the postcode instead of all 7
doubt i will get them before xmas, but i am not too bothered! just ordered them as spares!
fizzgog
me too, i ordered three even though i only need two :nono:
..pete
fizzgog
you beat me to it Candi
MST
I know that this is going to sound really lazy, but isn't there an easier way of finding out your Wii's serial number than looking on the back of the console?
nickp8
Well seeing as its the only place that has the serial number no!
Are you sure the wii is the right console for you? Sure you can be bothered to pick up the remote to play games? :p
Nickp.
raigraphixs
Nickp.
now that guy was lazy :D
just ordered 4 straps, just looked at originals, they seem so thin now!.
thanks for the heads up guys. :thumbsup:
MST
You guys are so funny that you should be on TV! I wouldn't mind but I even referred to how lazy the reply would make me sound when I posted it, it's a simple question to which there is obviously a simple answer. As I'm sure you well know It's possible to view the serial number of the Xbox 360 on both the front of the console and via the dashboard, and simply wondered if I could do the same with the Wii.
