replacement tv advice
stredwizard
Joined
Jan 16, 2022
Messages
2
Reaction score
Points
Age
46
Location
Hampshire, UK
Hi all,
Could use some advice on which TV replacement for our lounge, we have a circa 10 year old Samsung UE40D6510, which to be frank works absolutely perfectly considering its been switched on over the period for probably 12 hours daily.
We consume our TV content through an android TV OS box, which is connected to a Tvheadend back end with a mix of IPTV and Freeview channels and we use Kodi as the front end.
We were considering the Philips 43PUS8536, I was thinking as its android I could replace the android TV box, but not sure how well Kodi would fare on a TV or wether all the TV's remote buttons would be available in Kodi, such as guide, record being the main ones.
We would need to have access to the UK catch up services and although I understand the Philips TV has freeview play, we wont be using the built in tuner so are the apps available in a standalone fashion?
As the current TV is wall mounted on a narrow chimney breast, 43" is the maximum size and the positioning of the TV also makes the ambilight pretty in-effictive i would think so this is not important if there would alternatives that don't have it.
Hopefully someone has some experience of the above and can give me some directions please!
regards
You'll probably see lots of threads with similar outcomes but there's really not a good choice at smaller sizes. Best to wait for 42" OLEDs and save up some money, otherwise you may as well keep what you have.
thanks for your reply, I'm kinda stumped because we have no need for a 4k set as we don't have the content but if buying new its daft not too.
I think ill look for a decent universal ir/bluetooth remote as a stop gap instead.
You can buy a Roku or similar to turn your present TV into smart. People are doing that often with new TVs anyway.
The BIG PROBLEM With Your Home AV System EXPLAINED
Back
