Replacement sub-woofer
Discussion in 'Home Cinema Buying & Building' started by stevemorg2, Jul 12, 2015.
  1. stevemorg2
    stevemorg2
    Nov 8, 2009
    135
    Cardiff
    My Kef sub has given up (I may have a look at getting it fixed but I'm not sure its worth it!) - I need a replacement but if possible would like to avoid sending more than £200 or so - are there any alternatives to the BK Gemini?
  2. Eddie122333
    Eddie122333
    Oct 4, 2015
    4
    4
    Glasgow
    How much for your old kef
  3. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    The Wharfedale SW150 can be bought for around £150-180 I believe so is worth a look although I think I would prefer the Gemini.
  4. stevemorg2
    stevemorg2
    Nov 8, 2009
    135
    Cardiff
    Sorry - had the Kef repaired a while back at my local Audio T - £60 to fix was a lot cheaper than buying a new one!
  5. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    @Eddie122333
    for future reference, forsale, wanted and trade posts should only be posted in the correct classified forum.
    Curly
